Sub Wiring Options?
i have 8 SVC 8" 2ohm subs i would like to use for my HT sub. how could i wire these to get a 4 ohm final load so i wont fry my reciever/amplifier?
2003 Chevy Avalanche Z66
Headunit: Pioneer AVIC-F700BT
Amps: US Amps XT4000D, US Amps XT 1600.4
Front Stage: CDT Audio EF-61FG 6 1/2" components
Rear: Pioneer coax's
Sub Stage: RE SE15D4's
take 4 of the subs and parallel them = 2ohms
take 4 more of them and parallel them = 2 ohms
take the two sets and series them together = 4ohms
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
i know im askin alot but can someone maybe hook me up with a wiring diagram? i really wanna get it right the first time. thanks in advance!
As you have stated, you have Single Voice Coil woofers with an impedance of two ohms. Therefore, the above solution will not give you a final load of four ohms. The correct method will be to place two woofers in series so you have four pairs of woofers. Parallell two pairs together, then series the groups. To aid you, I have done up a circuit diagram.
However, this solution will not give you the exact value of four ohms. You will have approximately 6.4ohms at the terminals. Adding in extra factors, this may deviate slightly. I must warn you, running eight woofers off of a home cinema reciever is not a good idea. All eight woofers will not be used to their maximum potential, as most HT amplifiers are solid state amplifiers around 150w. Also, your damping factor will be affected considerably. But, your design is your design. Good luck and I hope it works out. As per usual, if you build it....
...post some fuggin pics.
Cheers,
Mick
Work;
DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS Venice
Meyer Sound CQ-1's, CQ-2's, PSW-2's
RAMSA Monitor Amplifiers
P.Audio Monitors
BSS OMNIDRIVE and Soundweb
DBX 231 and Klark Teknik DN360 EQ's
RCF TT22A
RCF ART320
