Iraqqi 300 Amp- Bad Idle?
I was about to purchase a Iraqqi 300 amp alt for my Yukon (biggest made) until I heard it had a shitty idle amp rating. Is this true, and if so, should I just go for a lower amp alt from Iraqqi?
I think its with all high output alternators. I have an excessive ampreage alt and when im beating at a stop light my voltage will drop to 11.3 but if im beating down the highway it wont move off 14.4. If i were you i would get dual alts with a lower rating. say dual 200 amps :)
DC.jpgDC POWER
Well because of the ECU and some other things I was just going to keep my stock alt and dual bracket the 300 amp alt.
i use alot of stinger alternators and have no idle problems 14.5 to 13volts the low idel could be. due to small pullys but i have no experince with iraggi so this may not apply
that's your best bet bro is to go with a stock and HO alt dual setup
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 3773 Guests (See full list)
