I hate to do a build log before I am completely done, but it looks like I won't get much else done between now and when I leave for Korea, and when I get back, I will probably upgrade, so the build will start over at that point.
Starts off as a stock Jetta with an upgraded head unit. Not the best of head units, but it does what I need for now. It is a Kenwood DDX-418. The GLI model comes with from the factory with a Monsoon audio system. This consists of a factory 8 Channel amp running a tweeter and woofer in each door. It sounded good, and got loud, but there was significant lacking of the low range frequencies. Anything below 80Hz was either distorted, or non existant depending on the frequency. What I was looking for in my build was to replicate the frequencies below 80Hz accurately, while still being able to crank up the bass when the song begged for it.
For my upgrade I decided to go with 2 Sundown SA-10D4s. I heard nothing but good things about the SA line from Sundown, and expected these woofers would perform to my needs. For power I figured I would try what was recommended by the manufacturer, and go with Sundowns own SAX-1200D which matches the RMS value of the woofers at 1 Ohm. I knew from the beginning that a properly built enclosure would make or break my build, so I researched and found a designer that like Sundown, had the most positive reviews.
I filled out a project assessment form after I decided on my equipment, and patiently waited for my design based on my parameters. What I got in return was exactly what I expected. Professionally completed blueprints with everything taken into consideration.
035 by jokers10, on Flickr
With that done I started on the build. And now the pictures: (sorry they are so out of focus and grainy. Using my iPhone 4.)
001 by jokers10, on Flickr
002 by jokers10, on Flickr
003 by jokers10, on Flickr
004 by jokers10, on Flickr
005 by jokers10, on Flickr
006 by jokers10, on Flickr
007 by jokers10, on Flickr
008 by jokers10, on Flickr
009 by jokers10, on Flickr
010 by jokers10, on Flickr
011 by jokers10, on Flickr
012 by jokers10, on Flickr
013 by jokers10, on Flickr
014 by jokers10, on Flickr
015 by jokers10, on Flickr
016 by jokers10, on Flickr
017 by jokers10, on Flickr
018 by jokers10, on Flickr
019 by jokers10, on Flickr
Edited by Toby Ratcliffe
020 by jokers10, on Flickr
021 by jokers10, on Flickr
023 by jokers10, on Flickr
024 by jokers10, on Flickr
025 by jokers10, on Flickr
027 by jokers10, on Flickr
028 by jokers10, on Flickr
029 by jokers10, on Flickr
030 by jokers10, on Flickr
031 by jokers10, on Flickr
034 by jokers10, on Flickr
And finally a video. Not really a lot going on here. Just 2 views of a 0-60Hz sine wave sweep. The quality isn't the best since yet again I was using my iPhone 4 and the image stabilization in iMovie.
It sounds mechanical, but almost all of the noise is from the cars body panels. I only have the trunk lid done with some peel and stick Rammat. Lots of interior noise in the second view. I will fix that over time.
http://www.youtube.com/watch?v=w8yuhexPZFQ
  • 2 months later...
from that last pic it looks like you carpeted the box inside the trunk, good job man
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
  • Who's Online   0 Members, 0 Anonymous, 1132 Guests (See full list)
