rboutin2 Posted May 1, 2012 Author Report Share Posted May 1, 2012 I dont have much of a choice on box size. I have a very limited amount of room, and I need to just make the best of what i got. What about the slot port displacement and volume thing? How do i figure up the tuning if it changes the volume, and the volume changes the tuning? Its like a catch 22. Quote Link to comment Share on other sites More sharing options...
will77530 Posted May 1, 2012 Report Share Posted May 1, 2012 start with your max dim enter those then enter your desired height for the port then adjust the width to get the right port area and obviously as you lengthen the port you decrease the volume of the box with the dimensions you listed your best option in my opinion is two six inch aero ports Quote Link to comment Share on other sites More sharing options...
412 CVX Posted May 1, 2012 Report Share Posted May 1, 2012 why did you buy your subs before you knew how much space you had? Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
rboutin2 Posted May 1, 2012 Author Report Share Posted May 1, 2012 I have been considering going back to aeroports also. Slots are best for when U actually have room. I just dont want the expense of them. I literally just built ym last box, and it broke along one of the seams. I underestimated the level 4 m2's, and didnt add enough bracing. I was running a box that was 46W x 21H x 16D, 1/2" indents, dual chamber, and 2- 3" aeroports per chamber. tuned to around 30 hertz. It sounded awesome, even got me my first noise ticket lol, but then I played rack city, and the box broke on the driver's side seam. I dont wana fix it, cuz I wana make it a bit bigger, tune a little lower, and im afraid its prolly just gna break again. Or leak. Quote Link to comment Share on other sites More sharing options...
will77530 Posted May 1, 2012 Report Share Posted May 1, 2012 sounds like you need practice building boxes Quote Link to comment Share on other sites More sharing options...
Tarball Posted May 1, 2012 Report Share Posted May 1, 2012 WALL the bish Quote CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
rboutin2 Posted May 1, 2012 Author Report Share Posted May 1, 2012 (edited) sounds like you need practice building boxes I have actually built quite a few boxes, and they have all sounded great, and never really had any probs. BUT, i dont usually do slot ports, never quite clicked with me, I've preferred aeroports. So, i dont mean to come off as rude, but Instead of criticizing, why dont u help me learn how to do slot ports so I can get better? WALL the bish I would love too, but my pickup is a daily driver, still gets used heavily as a truck, and I regularly pull a trailer. i kinda need my back window LOL Edited May 1, 2012 by rboutin2 Quote Link to comment Share on other sites More sharing options...
will77530 Posted May 1, 2012 Report Share Posted May 1, 2012 sounds like you need practice building boxes I have actually built quite a few boxes, and they have all sounded great, and never really had any probs. BUT, i dont usually do slot ports, never quite clicked with me, I've preferred aeroports. So, i dont mean to come off as rude, but Instead of criticizing, why dont u help me learn how to do slot ports so I can get better? WALL the bish I would love too, but my pickup is a daily driver, still gets used heavily as a truck, and I regularly pull a trailer. i kinda need my back window LOL i did..... also said you dont have the volume to do a slot port Quote Link to comment Share on other sites More sharing options...
Tarball Posted May 1, 2012 Report Share Posted May 1, 2012 make the box for one 15 and use the other as a backup for if/when you blow it. Quote CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
412 CVX Posted May 1, 2012 Report Share Posted May 1, 2012 or, use both and go sealed. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
