Quick battery question...
Im in need of a batteries for my install, right now I have a shuriken bt-20. I wanted to get a yellow top for the front or something similar. Im running a Planet Audio BB2400.1 and was wondering if I get a second bt-20 for the back and run it inline with the other one and do tbe big 3, would that be enough. Im on a strict budget!
in all honestly id replace the front 1 first, do the big 3, and see where youre at as far as voltage and how long you can keep your voltage where you want it, also whats the size of your stock alt?
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
i use to have a rx2400 from pa (all most the same amp) and i had a yellow top 6 runs of 1/0 and 2 more g31 plus a high output alt and i still was droping down to the 12-11 volts from all most 15
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
40ah worth of battery no...
therre are MUCH better batteries than a optima..
and if you want a shuriken bt100 i have one resting voltage is 12.9v.. im not far from cleveland and ill let it go for cheap
and i retract partially what i said..didnt realize that batt was that small lol and youre correct theres way better than yellow tops for the front..reading>me on that one a bit
power: dd m4
lol, I was thinking of the yellow top because AutoZone has them for $140 I believe, that is if its still discounted. How much for the bt-100? I can get it asap!! And my stock alt I think is 105amps..
  • Who's Online   1 Member, 0 Anonymous, 1212 Guests (See full list)
