on the port, try putting 21.50h, 6.25w, 20L. that gives you 134 port area, but 17.68 of port per cube with 3 common port walls. this is without displacement, which can be adjusted through. fyi, im using torres calculator.
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
btw, is it going to be a double baffle?
The box is 8.2 cf,after displacement's,131 sq in of port,but when it come's to length of port,i'm stuck.I want it tuned to 38 hz,and some site's say,16.54 in long,while other's say 20 in.Two 15's are going in there,and basically,I just want it to slam super hard on music.Any help?
Better tell what car what subs what amp or you are going to get a guessed port, you may also need some bracing..
  • Who's Online   1 Member, 0 Anonymous, 722 Guests (See full list)
