what am i readin
Current Setup: , 2 Fi sp4 18s in a big ass flat wall tuned to 23hz, Pioneer 80prs, 2 Digital Designs m3bs strapped @ 2 ohms, Banda ICE2000, Crescendo 800.4, 4 PRV 10MR1000s,4 Mclaren MLT300 Super Tweeters Kinetik 2000 XS Power 2700 & XS Power 3100s.
You ground no pos. to the chassi´s, OK????
Positive is going in amps and co, damn you have 1300 post.
At last from negative to negative @ the batteries is the best ground, your backbattery is than chassisgrounded with the normal place from the
under the hood batt. If you want fit the groundplace of your hoodbatt, sanding + copperpaste on the place.
"in the abundance of water, the fool is thirsty" Bob Marley
Perhaps I used the wrong term.. Still I tad confused neg to negative then positive to positive? I'm probably way off here.. Sorry if I'm speaking noob.
Edited by TheNewbie
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
For 1300 post´s it sound real noob. Pos. to Pos. and Neg. to Neg. The Hoodbatterie is naturaly grounded threw the frame.
Is it possible to ground it without doing another run to the back battery?
no doubt, my appoligies thank you for the help sir. Pretty self explanatory just didn't really want to do a neg and pos run through the car Thanks again
i think hes just asking if there is a problem grounding his back battery to chasis instead of grounding it to front battery, since he doesnt have enough wire to do another run to the front.
Made simple. Thank you sir.
EDIT: Now on a computer, so I should be a tad bit easier to comprehend.
Edited by TheNewbie
  • Who's Online   0 Members, 0 Anonymous, 1671 Guests (See full list)
