dd 3512 box help!
in that case if you have no back seat. just seal it off from the trunk all forward
ok so what we got goin on all sealed off forward mounted ports and drivers at 15''h 25''w 25''d
2 6'' areos 15'' long
4.31ft^3total vol
56.52in^2 port area
3.78ft^3 net vol
and 43.59hz
this all sounding in the right direction?
tuning is too high
ok lets see how you like these,
15''h 35w 25d same port size and length but its now 6 cubes at 35hz
how would i lower hz but keep it in the size range
longer ports, make box bigger or smaller 1 inch at a time until your where you need to be
also for 2 6" aeros to fit on your box face you'll either need to not use the outter flange or cut them so they fit...they flair out to 9 inches each. you can also do 4 4" areos and get roughly the same results.
i was planning to cut them to size, right now im sittin at
15x27x27
2-6'' 17'' internal and 10'' external 5.08ft^3 at right at 36.78hz
  • Who's Online   1 Member, 0 Anonymous, 1292 Guests (See full list)
