Jagraj7870 Posted May 5, 2012 Report Posted May 5, 2012 I was wondering if this would work, i wanna make pods and i was looking at the seleniums (6W4P) and the new small amp that RF came out with. the amp is a Rockford Fosgate PBR300x2 which is capable of: RMS Power Rating: 4 ohms: 100 watts x 2 chan. 2 ohms: 150 watts x 2 chan. Bridged, 4 ohm: 300 watts x 1 chan. and the seleniums are 6" 8 ohm Specifications: • Power handling: 100 watts RMS/200 watts max • VCdia: 1.25" • Le: 0.57 mH • Nominal impedance: 8 ohms • Re: 5.9 ohms • Frequency response: 80-9,000 Hz • Magnet weight: 19.8 oz. • Fs: 76 Hz • SPL: 91 dB 1W/1m • Vas: 0.28 cu. ft. • Qms: 6.7 • Qes: 0.95 • Qts: 0.83 • Xmax: 2.3 mm • Dimensions: Overall diameter: 6.54", Cutout diameter: 5.63", Depth: 2.9". - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
hdorre Posted May 5, 2012 Report Posted May 5, 2012 Do you plan on getting an external processor to bandpass the mids? On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
SmallTruk Posted May 5, 2012 Report Posted May 5, 2012 of course it'll work, you just won't be getting as much power to them. at 8ohms it'll probably be somewhere around 75w
Jagraj7870 Posted May 5, 2012 Author Report Posted May 5, 2012 of course it'll work, you just won't be getting as much power to them. at 8ohms it'll probably be somewhere around 75w But then it says bridged 4ohm 300 watts. does that mean it would do 150watts to each speaker? if i was to wire it 4 ohms? - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
