Team Bassicks Civic Build 12 DC 10's *New Plans should I???*
:popcorn: you can't be as loud as me alpine. just stop. but i would like to see moar pics :peepwall:
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
did a lil work today....
skittles didnt have faith in my port so i thought it would be a good time to test fire it see where i stand
putting it together and wiring subs
got the supports in the middle
was working didnt take many pics
all wired up wires out the port for testing
the kinetic batts will not go there by the way
so my testing went like this i was guessed (hoping for a 152) just sitting there peaking in the low 40hz range
skittles said 148.x at 55hz lol no faith!!!
this is with 1 batt and the stock Alt dropping to 10 volts
well it did a 150.8 at 58hz :( sad face with no trim panels nothing :jon: Skittles lol
SO i got to add port not a problem i will get tunning to the 38 range but it just didnt sound like the subs were even close to being pushed and i thought the 150.8 was hella weak so we clamped the amp starting nominal load 1.3 3x rise to 4.3 ohms volts droping to 10 volts did 2500 watts and some change thats 200 watts per sub 1/3 the rms of the subs looks like i might have to add 1 more 7k to split the rise and wire lower
not a bad start for my frist clam shell add more power fix tunning i think a 156 is possible when its done sealed off and all pretty going to roll with this
Good stuff alpine.....;-)..now ya see why I wire so low I have 2.7 ohms of rise myself..how you goin to add to port? Put l pieces on inside edges?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
ya probably redo the the inside clam part make it longer and add an L piece shrink the port some to
i have a feeling you can make it louder on less power. With that much cone area.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
well my car DOES NOT like 58 hz so there is a gain there when i change the port and remeber its not sealed off from the back good db or 2 right there so yes there are some good gains left but 200 watts a subs is weak time to get 1 more amp wire lower ang close to 10k out of the 800 watts a sub sounds so much better these subs were laughing at me with 200 watts
was a nice wind tunnel in there my shrit was going crazy and only gained .4 dbs by opening a door
also remeber this was 1 batt droping to 10 volts as well JUST A TEST now i know to tune WAY lower before i do anything eles
what batt are you exactly using, i saw you have 6, and staying with the stock alt?
Kenwood H/U
1/0 wire,
i was useing the stock die hard and stock alt for the test
i have 7 kinitec 16v's and a 16 volt alt going in but will be useing the 12 volt side of the batts i have to charge these batts at 17 volts tho
Not a bad start.
You know what to do so...
:popcorn:
