my guess is voltage drop. do you have the big 3 done? are your grounds bolted to the frame/strut tower with the paint sanded off?
X2 with Kranny (as usual) do BOTH amps, and drivers on those amps stop? or just one, and not the other?
Like K said, if your losing BOTH, then voltage/ground and anything with both has to be the issue......Meter time....
Bad connection on either ground or power so when it hits hard it breaks the connection and shuts the amp down.
Check every connection on power and ground and see which one is not tightened making a good solid connection.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Losing just one... Had the voltage checked yesterday and it checked out
im guessing this means u went to an auto parts store and had them check your voltage? that will not tell you if you have volage drop. you need to put a meter on the amps and monitor the voltage when it shuts off
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
only had that happen when my second battery's power wire came undone
Current Setup: , 2 Fi sp4 18s in a big ass flat wall tuned to 23hz, Pioneer 80prs, 2 Digital Designs m3bs strapped @ 2 ohms, Banda ICE2000, Crescendo 800.4, 4 PRV 10MR1000s,4 Mclaren MLT300 Super Tweeters Kinetik 2000 XS Power 2700 & XS Power 3100s.
