Crandis16 Posted May 9, 2012 Author Report Posted May 9, 2012 maybe you can try it this way that looks like the same, except the accessory and the power are switched? That could have been what you did wrong. If the power and acc are switched then the LED side of the switch could get constant power regardless of switch position. The switch will still work fine otherwise. thats what i was thinking cuz i have an illuminated rocker switch not like yours but where the entire thing lights up and when i first got it it had the same problem i tried it like this(basically) and it works like its supposed to I'll give this a try, I know some of the cheapo switches (radioshack) don't label the leads so it's a guessing game as to which is right or not lol My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
Crandis16 Posted May 9, 2012 Author Report Posted May 9, 2012 If that doesn't work you could always use a relay and use 30 to supply the 12v switched and use your amp turn on to trigger the relay from terminal 86... So relay would look like this: 85 ground 86 12v switched 87 12v constant 30 output to the 12v switched side of the switch Or like others said get a switch that works >.> I just ordered up some that look exactly like that and I'm hoping not to have to use relays on them to keep them from illuminating constantly... If I get a new switch and it doesn't work the way I want then I will just buy an unilluminated toggle switch But that takes the fun out of it! If you have a wiring diagram then that would make things a lot easier. I'm a mechanical engineer, electrical can be confusing to me sometimes lol. I only do simple circuits right now My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
Junior Russell Posted May 9, 2012 Report Posted May 9, 2012 maybe you can try it this way that looks like the same, except the accessory and the power are switched? That could have been what you did wrong. If the power and acc are switched then the LED side of the switch could get constant power regardless of switch position. The switch will still work fine otherwise. thats what i was thinking cuz i have an illuminated rocker switch not like yours but where the entire thing lights up and when i first got it it had the same problem i tried it like this(basically) and it works like its supposed to I'll give this a try, I know some of the cheapo switches (radioshack) don't label the leads so it's a guessing game as to which is right or not lol lol yeah the only thing you have to remember ground is never center still got a burn on my hand from finding that out the hard way http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
Cashdollar2009 Posted May 9, 2012 Report Posted May 9, 2012 I would think that it would have to be the switch. If you wired according to the diagram, then it should work. Maybe before tossing the switch, wire the "power" to the yellow wire from your deck (switched 12V) therefore the switch would ONLY be seeing 12V power to operate when the radio is powered up. On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not.
Crandis16 Posted May 9, 2012 Author Report Posted May 9, 2012 I would think that it would have to be the switch. If you wired according to the diagram, then it should work. Maybe before tossing the switch, wire the "power" to the yellow wire from your deck (switched 12V) therefore the switch would ONLY be seeing 12V power to operate when the radio is powered up. I never thought of doing that, I hate wiring behind the HU but it needs to happen. check out my build log, bro My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
JasonJones Posted May 9, 2012 Report Posted May 9, 2012 I would think that it would have to be the switch. If you wired according to the diagram, then it should work. Maybe before tossing the switch, wire the "power" to the yellow wire from your deck (switched 12V) therefore the switch would ONLY be seeing 12V power to operate when the radio is powered up. I never thought of doing that, I hate wiring behind the HU but it needs to happen. check out my build log, bro Just to let you know the Yellow wire from an aftermarket head unit is 12v constant. Red is 12v switched.
Crandis16 Posted May 9, 2012 Author Report Posted May 9, 2012 so the red (power) behind the HU will activate the switch when the HU is turned one? My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
Eduardo Andrade Posted May 9, 2012 Report Posted May 9, 2012 wouldn't you just need a 2 prong switch? I dont see the need for the ground just something that completes the circut, I mean you're just using this for the turn on lead, right? Clarion CZ401 Power Acoustik LT-980/2 dbLink 8 gauge kit DXi 104 4 ohm DVC x2 Sealed Enclosure
JasonJones Posted May 9, 2012 Report Posted May 9, 2012 so the red (power) behind the HU will activate the switch when the HU is turned one? Yes, it's the same as switched power.
Crandis16 Posted May 10, 2012 Author Report Posted May 10, 2012 wouldn't you just need a 2 prong switch? I dont see the need for the ground just something that completes the circut, I mean you're just using this for the turn on lead, right? yes, but I want an illuminated toggle switch, which has 3 prongs, not as simple so the red (power) behind the HU will activate the switch when the HU is turned one? Yes, it's the same as switched power. thanks, I always thought that it was the red had constant power and yellow was switched My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
