CstrokerV Posted June 26, 2012 Report Posted June 26, 2012 http://www.ebay.com/itm/CERWIN-VEGA-CXA-8-POWER-AMPLIFIER-for-Professional-Home-Audio-1800watts-NEW-/150829964438?pt=US_Home_Audio_Amplifiers_Preamps&hash=item231e2a9c96#ht_971wt_1185 heres the home version but its 800 bucks Quote my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
b-dubs89 Posted June 27, 2012 Author Report Posted June 27, 2012 (edited) got a kenwood pre-amp with rca's , i knew when i seen the back of the cv 900 i would need to buy or make some cords to connect it i went back to look at it again and it says xlr or trs connector and looking at the back of the amp it looks like i could run balanced or unbalanced input , correct me if i am wrong but i think with the right adapters or connectors maybe the cv900 could be a go the cxa-8 runs on 220 volt which would be a big pain to get that going in my house Edited June 27, 2012 by b-dubs89 Quote
CstrokerV Posted June 27, 2012 Report Posted June 27, 2012 theres an adapter at parts express from rca to xlr but i read somewhere that it drops part of the lowend not sure how much it might say on the site just found this too http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-438 Quote my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
PawełKapela Posted July 5, 2012 Report Posted July 5, 2012 CV-900 is shit.. Here good and heavy AMP http://www.thomann.de/gb/t-amp_ta2400.htm Quote
b-dubs89 Posted July 5, 2012 Author Report Posted July 5, 2012 CV-900 is shit.. Here good and heavy AMP http://www.thomann.d...-amp_ta2400.htm thanks for the suggestion , but the amp you suggested is big overkill for 1,2 i would have to run a 220volt line to be able to plug it in . i hope the cv-900 isn't shit cause i bought it , should have it next week . Quote
Question Mark Posted July 6, 2012 Report Posted July 6, 2012 CV-900 is shit.. Here good and heavy AMP http://www.thomann.d...-amp_ta2400.htm thanks for the suggestion , but the amp you suggested is big overkill for 1,2 i would have to run a 220volt line to be able to plug it in . i hope the cv-900 isn't shit cause i bought it , should have it next week . PA amplifiers more than enough on these kind of loudspeakers. CV! isn't famous for high-end sound That T.amp is for us in europe and you would have a transformer to convert 220 to about 110Volts plus converting 50 to 60Hz. It also comes with no softstarter.. Personally I would of purchased a Crown XTI 2002 over the CV-900. It gives just about the power you need and wouldn't have to boost the bass which you probably will with the CV-900 I've heard nothing, but good about Crown and unfortunally I can't say the same about CV amps :/ Quote
b-dubs89 Posted July 10, 2012 Author Report Posted July 10, 2012 just to update i got the cv-900 today and it definitely drives my big vegas better than my theater amp did , but i think i was expecting a little more .the amp isn't the cleanest i have ever heard but it isn't offensive to my ears most of the time . i have a tripp lite power conditioner coming and i am hoping that will improve things a little . the bass was making my vegas start walking quite a few times Quote
