Audiojunkie23 Posted May 10, 2012 Report Share Posted May 10, 2012 Haha ok i will turn those down... all the way ? Checked the internet and found the total capacity of the trunk which is 480 Liters metal plate behind the rear seat: https://www.dropbox....9h/Naamloos.png Ive already cut a hole on the red lines Planning on cutting on the green lines an screwing an MDF plate on it.. Good idea ? Trunk Dimensions (in CM) https://www.dropbox..../Dimensions.png Nah don't turn your gain all the way down. Just your bass boost. I would look into getting a DD-1 so you can set your gains properly and not have any distortion. Totally worth the money in the long run. Quote Link to comment Share on other sites More sharing options...
nahinder Posted May 10, 2012 Author Report Share Posted May 10, 2012 How do i order a dd-1 from here.. Does Steve send them to europe ? Quote Link to comment Share on other sites More sharing options...
Audiojunkie23 Posted May 10, 2012 Report Share Posted May 10, 2012 They are actually on amazon now. Check it out. http://www.amazon.co...rds=smd+dd1+cc1 Quote Link to comment Share on other sites More sharing options...
Joe X Posted May 10, 2012 Report Share Posted May 10, 2012 OP you list a single amplifier for the sub, so the speakers are being run directly from the head unit right? If so the distortion you hear on them has nothing to do with the sub amp settings. Quote Link to comment Share on other sites More sharing options...
Audiojunkie23 Posted May 10, 2012 Report Share Posted May 10, 2012 OP you list a single amplifier for the sub, so the speakers are being run directly from the head unit right? If so the distortion you hear on them has nothing to do with the sub amp settings. X2 I'm just trying to save your woofer and if you get a different for your speakers then the DD-1 will help with that also. Quote Link to comment Share on other sites More sharing options...
nahinder Posted May 10, 2012 Author Report Share Posted May 10, 2012 OP you list a single amplifier for the sub, so the speakers are being run directly from the head unit right? If so the distortion you hear on them has nothing to do with the sub amp settings. Thats right but somehow the speakers cracks on low and hi volumes. And for the SUB its still wired in series so it's playing on 8 ohms right ? Quote Link to comment Share on other sites More sharing options...
nahinder Posted May 10, 2012 Author Report Share Posted May 10, 2012 Just checked the Speakers Here are some pics: MIdBass https://www.dropbox.com/s/2i886u7x1h211xf/2012-05-10%2017.29.21.jpg Tweeter https://www.dropbox.com/s/kiws85dzxsniouy/2012-05-10%2017.29.47.jpg Wired like this https://www.dropbox.com/s/1qgx8x9f1appfix/2012-05-10%2017.30.10.jpg Quote Link to comment Share on other sites More sharing options...
Joe X Posted May 10, 2012 Report Share Posted May 10, 2012 Ok it always did the same or at some point started doing it? Quote Link to comment Share on other sites More sharing options...
nahinder Posted May 10, 2012 Author Report Share Posted May 10, 2012 Ok it always did the same or at some point started doing it? It was always like this Quote Link to comment Share on other sites More sharing options...
nahinder Posted May 12, 2012 Author Report Share Posted May 12, 2012 Just found the Cross over for the Tweeters: https://www.dropbox.com/s/gk5f81evpcq49nn/2012-05-12%2015.33.39.jpg So that shouldnt be the problem.. Just saw Steve's ISF plans Im planning on doing something similar, any tips ? Quote Link to comment Share on other sites More sharing options...
