SilveradoGoesBang Posted May 10, 2012 Report Posted May 10, 2012 (edited) Hey guys this box is going to be in a extended cab truck with subs foward port up and centered on the back. Its for 4 vvx 15s d2 and would like about 10cubes for them and the box to be tuned to 32hz. Ive been playing with torres and i cant get the tuning to 32 and keep the port area per foot from getting to low. if somone could take a look and help it would be awesome! Dem. 58w 26h 19d heres where im at Edited May 12, 2012 by AltimaGoesBang Quote "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
SilveradoGoesBang Posted May 10, 2012 Author Report Posted May 10, 2012 came up with this but port area per foot is way to low Quote "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
SilveradoGoesBang Posted May 11, 2012 Author Report Posted May 11, 2012 Bedtime bump help me lol Quote "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
john253a Posted May 11, 2012 Report Posted May 11, 2012 if you do port up it will still be an L-port and will end up facing subs you may be better off facing it forwards also your subs ar 16"OD and will not fit straight across, you can stagger them to fit light so, or like the olympics rings Quote
john253a Posted May 11, 2012 Report Posted May 11, 2012 or you could do port up with 3x 6" aero's 19" long 1" box with either 3/4 or 1 baffle Quote
SilveradoGoesBang Posted May 11, 2012 Author Report Posted May 11, 2012 Okay how much port area per foot should I be looking for? Quote "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
Guest Posted May 11, 2012 Report Posted May 11, 2012 (edited) you know you can go in half and quarter inch increments for the port height and width, right? you dont have to have whole numbers. edit: you better put some bracing in that box too, or expect it to rip itself apart after a while. Edited May 11, 2012 by Kranny Quote
SilveradoGoesBang Posted May 11, 2012 Author Report Posted May 11, 2012 you know you can go in half and quarter inch increments for the port height and width, right? you dont have to have whole numbers. edit: you better put some bracing in that box too, or expect it to rip itself apart after a while. K and im gonna use wooden dowels as bracing just dont have a exact number to put in the box for displacement. Quote "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
RooTxBeeR Posted May 11, 2012 Report Posted May 11, 2012 you know you can go in half and quarter inch increments for the port height and width, right? you dont have to have whole numbers. edit: you better put some bracing in that box too, or expect it to rip itself apart after a while. Shit, I go farther than that. If you want to see a number in a box design, you need to make shit precise. For those that are math incompitent. 1/16 .0625 2/16 .125 3/16 .1875 4/16 .25 5/16 .3125 6/16 .375 7/16 .4375 8/16 .5 9/16 .5625 10/16 .625 11/16 .6875 12/16 .75 13/16 .8125 14/16 .875 15/16 .9375 These are each of those little dashes inbetween every inch on tape measure for those that didn't know. Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
john253a Posted May 11, 2012 Report Posted May 11, 2012 Okay how much port area per foot should I be looking for? There is no exact number But a rule of thumb is Aero 9-13"sq per ft Squar 12-16"sq per ft Slot 12-16"sq per ft (9:1 scale or less) Quote
