weigh them and look them up that way?
02 Ford Focus ZX3 hatch
4-Infinity Kappa 682.9cf's
DC Lvl 4
Hifonics BRZ 1200.1 @ 1 ohm
Kicker Wires
Rockford RCAs
Future Upgrades
Knu 1/0
XS Power D1200
80 mil audiotechnix B stock
pull them out and look at the motor/take pictures. there should be something on the back of the motor stating what it is.
i have looked there is nothing to tell what they are... they look just like all the newer RE audio subs from the back. they have the RE stamped in the basket and have the cover of the motor to cool it and the RE on the back just like all the new ones. but when i look on the RE audio web site the RSX is only dvc 4 ohm and does not have a motor cover also my subs are dvc 2 ohm , and its stupid cuz when i look like on Ebay they sale RSX with dvc 2ohm, and with motor cover but like i said on the site they say they are only dvc4 so idk. i can not even find pic of old RS line of sub to see if they are built the same. i dont want to pull the subs out just to take some pics i will put a pic of what they look like from other stuff online that look the same.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
reaudio4.jpg this is what my subs look like.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
reaudio5.jpgthis is the pic from the re audio website of a srx, my basket is the same but my subs have the motor cover Edited by sbg
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
You indeed have the first gen SRx's. The first x's had the ugly black plastic cover over the magnets. The ones I got back from RE after ripping my surrounds completely off had the nice bare magnet(with rubber boot) when I got mine back from warranty. The subs will take some abuse on the coils, but the soft parts will fail if you overpower them too much.
they just say SR on the cone small and they are good subs even if they are just sr's they are hiting at 145.3 i am runing them at .5 ohm but thats not why my amp was cuting in and out 1 of the wires inside the box was jacked up. my amp runs good at .5 does not even get hot at all also have a planet audio ap 1500d i use on the subs at .5 and never have a problem with that amp to so its all good. i will try to post pis of the subs.... from what i was told the older RE audio stuff " SR" were a better sub then the new stuff."srx"
Also, you kind of contradicted yourself here. You said that this amp will cut out from time to time, but also said its NO problem running this amp at .5 ohm. If your amp is cutting out, clearly there IS a problem, like going into protect from too much heat.
no amp does not get hot at all, it was just a wire in the box from the sub to the termanial on the box . after i fixed that it has not cut out at all. what kind power u runin to yours? my amp is puting 550 RMS to each sub. and i dont think the plastic cover over the magnets is ugly, and they help to cool the sub. i like the magnets with no cover to but i dont care because they are in the box so its whatever. also do u know the rms and peak watts on the subs? i fell like im at the peak of them for what im runing.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
lol i keep puting rs when they were SR lol but i was drunk at the start of this
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
