wouldnt recommend running an amp below one ohm daily, that low load puts alot of strain on an amp, but if you really want to do it you should get a dual alt kit, and probobly 3 large agm sealed batteries, big three upgrade in 0 gauge, you could also add some dual 0 gauge reducers to the amp to run two powers and grounds to the amp
its possible to do it like that but you would need two seperate amps to do it and there is alot of calculation and science to setting the gains and frequincies, crossovers and what not correctly to make it sound right, the simpiliest way to do it is to just build a traditional ported box for the subs
Edited by bass_stalker
Yea probly biting off more than i can chew on that one. Any suggestions on box design? I was thinking forward facing with port also forward below the sub...? Sorry so many questions just want to get this right the first time.
i would ask skyhigh car audio for some advice since he did a large build in a truck simular to yours
heres a link to his new build since i dont have a link to his old one http://www.stevemead...gmc-sierra-ubl/
scratch that look here http://www.stevemeadedesigns.com/board/topic/114678-gmc-sierra-2500hd-4-15-dc-xls-12k-ipad-video-posted/page__fromsearch__1
scratch that look here http://www.stevemead...__fromsearch__1
Thats pretty close to what I had in mind for my doors too. Was gonna glass those grilles to angle to component sets in each door. Glad I finally saw a pic of something pretty close! Thanks
honestly if you already have the yellow tops. use them. nothing wrong with them. when they die off or your needs become larger upgrade later.
honestly i would go with the 2 subs. once you figure out what subs you want to use, you can figure out a design for the enclosure and then figure out what power you need
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
trust me ive been around with no experience and no one to help me, i know how it feels, good luck on your install whenever you decide on what you want
