To rule out amps...how are are subs wired to amps..meaning from top to bottom..or did you do from left to right..what's your peak freq?they should move less there..
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
never did it with the SA10s tho!
it wasnt the same box though was it?
exact same box, pulled SA10s out sat after show had XFLs in by sunday at 10pm
heres a quick vid
only really noticeable at 5 sec in and right at the end, the pinging noise IS NOT THE SUBS! lol
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
its probably a loading issue. running many subs (or even two) with the port on one side is notorious for causing that problem.
heres a shit wiring diagram
basically, theres 6 subs per pair of 4500s, at 1.2 strapped
theres 4 sets of .66 loads, which i seriesd to 2 1.2 ohm loads
so each pair of amps has 6 subs at 1.2 strapped
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
I know you probably have check the subs to see if you got the correct coils, I had 2 of my 16 subs show up and it had dual 4's the rest were dual 2's.
sounds like scratching....maybe
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
if you want to keep the same box, and if its a box problem, put 10" sono tubes behind every sub that are at least as long as the sub is deep. im not sure what length would be best though. that will help even out the pressure behind each sub.
both sides read 1.2ohm on DMM
shitty camarah ftl theres no scratching
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
