fx4trucker Posted May 13, 2012 Report Posted May 13, 2012 i was looking at the RE audio 6.5 xxx component speaker($279) i saw that they are 2 ohm. i need 3 sets of them (a total of 6 woofers and 6 tweeters) i plan to wire the woofers to 1 4ch. same with the tweeters to another 4ch. so question is should i wire 2 wofers to 1 ohm or to 4 ohm.that would be ch 1& 2 leaving 3 & 4 for one set . i know there there not may 1ohm 4ch out there and that they are not cheep. alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers. 1. set is in the a-pilors 1. memphis mojo 2500 watt amp 1. rockford fosgate t2 15" dual 2 ohm wired to 4 ohm . seeing 600 watts 1. realm audio 600 watt 4ch
profundus-sanus Posted May 13, 2012 Report Posted May 13, 2012 with 1 4 chn per 6 speakers you would have to do 3 speakers in series on 2 channels bridged. so you would be at 6 ohms bridged or the same power as 3 ohm per channel. Which pretty much any 4 channel will handle. if you wired 3 in parallel on 2 channels you would be at .67 bridged or .3 per channel, which no 4 channel will handle that i'm aware of.
bumonskateboard6 Posted May 13, 2012 Report Posted May 13, 2012 Run 2 6 channel amps instead? Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
