I just got on trade an older Majestic 60 watt 4 channel amp. The ground is bad on it but it comes on then back of. The amp does not have the screws for the power ground and remote like newer ones it just has an opening that has the wires coming out from them. Can this be fixed? Am I even correct that the ground is bad? :help:
Edited by BrandonT94
that ground should be fixed for sure....looks pretty narly bro
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
Edit: Re looked over, yeah you should redo that ground.
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
x-whatever on redoing that ground. do it properly though, not like the previous owner did. thats a shit solder job to be honest.
get a soldering vacuum plunger or however you'd like to remove as much solder from that spot as possible, clean up the hole really well with rubbing alcohol, stick new wire in, solder to board. you should be good to go then.
well the wire should be going through a hole in the board for it to pass through, and get soldered.
i dont really understand what you mean by it being in line with the silver trace thats there now. just put the wire in and solder it.
thats a really fucked up solder job right there, so try not to duplicate that lol
never seen the 4 channel ones, i got a 2ch majestic amp
does ok for a 90's amp i think, not alot of power tho
  • Who's Online   0 Members, 0 Anonymous, 1429 Guests (See full list)
