Where can i get aero ports 5 inches in diameter and 22 long.
Edited by MIKE-2U
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
the only thing i could think of would be try to find some concrete tube (cardboard) and get as close as you can to 5 inches then maybe modify to be 5 inches..then fiberglass the hell out of it... it "might work" or just do it with 4's,6's, or 3's and make i easier
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
the box design i was given has 4 5" ports, how would i go about changing it ?
plug it into torres and play with 6" aeros till you get i where you want it...or post up your dimensions and someone can do it for you..
power: dd m4
x2
"Damned if i do, damned if i don't..."Sold to: RodeoSport, deeppinkdiver, kevosinn, CortezDTV
Bought from: SlamminBeats, Carboardcat15
box is for an 18" dc in bonneville trunk
High - 15
wide - 42
depth - 32
currently has 4 5" 22 inch long aero ports along bottom.
Got to remember depth of sub and aero ports measure about 6" high in box.
All dimensions except the height can move +/- 2 inches . a sketch up would be awesome when done. thanks a bunch .
IF you have any other suggestions or designs feel free to share
what power and what DC sub?
power: dd m4
AQ 2200 soon and dc level 4 with lvl 5 coils M1
