I guess the only way to answer that is how much room do you have under the hood.
The hc800 is 900 amps.
Here is a pdf file of the yellow tops. unless you can squeeze a d31 under your hood id recommend the hc800
Also depending on where you would buy your yellow top at, the hc800 will be alot cheaper then any yellowtop model.
lol well thank you for you drunken responces :P j/k!
Lol as the crown royal commerical goes.
"its about quality, not quanity!"
Im not drunk just "relaxing"
man work is going to suck today i should really goto bed but this crown is so good.
really a toss up...i love my yellow top
reason i have it is because i bought it before i knew about kinetik and i wasnt gonna buy a new battery if that one is perfectly fine. i would say go kinetik. though
yeh i'm with Chode. i myself have a yellowtop but this guy i know wants to upgrade his stock battery and heck i'm going to sell him my yellowtop and get a HC 1800 or HC2000. i just hope the kinetik doesn't let me down.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
would it matter if i got a bigger battery then the HC800? because i can fit a HC1800 up front. Would there be much of an advantage getting the larger one? or would i be better off getting a hc800 for the front and a hc1800 in the back? Im just concerned that the Hc800 might be a lil too small....
