Yellow Top? Or Hc 800?
I guess the only way to answer that is how much room do you have under the hood.
The hc800 is 900 amps.
Here is a pdf file of the yellow tops. unless you can squeeze a d31 under your hood id recommend the hc800
Also depending on where you would buy your yellow top at, the hc800 will be alot cheaper then any yellowtop model.
really a toss up...i love my yellow top
reason i have it is because i bought it before i knew about kinetik and i wasnt gonna buy a new battery if that one is perfectly fine. i would say go kinetik. though
NoFearX18 said:
trainman0978 said:
yeh i'm with Chode. i myself have a yellowtop but this guy i know wants to upgrade his stock battery and heck i'm going to sell him my yellowtop and get a HC 1800 or HC2000. i just hope the kinetik doesn't let me down.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
would it matter if i got a bigger battery then the HC800? because i can fit a HC1800 up front. Would there be much of an advantage getting the larger one? or would i be better off getting a hc800 for the front and a hc1800 in the back? Im just concerned that the Hc800 might be a lil too small....
  • Who's Online   0 Members, 0 Anonymous, 392 Guests (See full list)
