Guest Posted May 23, 2012 Report Posted May 23, 2012 you have to measure down the middle of the port for port length. you dont measure the lengths of the port boards. Quote
scottam Posted May 23, 2012 Author Report Posted May 23, 2012 you have to measure down the middle of the port for port length. you dont measure the lengths of the port boards. im not quite sure by what you mean. i took the length of 20 then took .75 (the size of mdf) and got the 19.25 but just rounded it to 19 out of sheer laziness Quote
412 CVX Posted May 23, 2012 Report Posted May 23, 2012 physical port length is the length of the port walls. use that number instead. and make your baffle so it takes up the full length and width of the face. like so. also, you're going to want some crossbracing front to back. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
scottam Posted May 23, 2012 Author Report Posted May 23, 2012 physical port length is the length of the port walls. use that number instead. and make your baffle so it takes up the full length and width of the face. like so. also, you're going to want some crossbracing front to back. Ok. Looks good. I fucking hate sketchup I'm a much more pshyical learner so when I start I'll get all that in there. Also Would a double baffle be a good idea and instead of bracing top to bottom would some threaded rods front to back also work. Quote
AI James Posted May 23, 2012 Report Posted May 23, 2012 wow, your getting close to content of fail thread of all time here Quote
scottam Posted May 23, 2012 Author Report Posted May 23, 2012 wow, your getting close to content of fail thread of all time here Thanks appreciate it. Quote
