mrwigglezdj Posted December 26, 2007 Report Posted December 26, 2007 well it was easy to do the 8 6.5's to the amp at 2 ohm, but now ive got more 6.5's and the 4 tweets im starting to confuse myself ect. mids will consist of 12 6.5's single 4 ohms @ 50wrms each and 4 1inch tweets unknown ohm's @ 50wrms for a total of 16 speakers total, i can get a 4ch amp and run 4 speakers per ch, and have 1 tweeter on each ch, so it will be 3 6.5 and 1 tweet per ch.... and thats 1ohm or 4ohm? if the tweet is also 4ohm.... i think i answerd my own question but can someone double check and makesure im on the rite track, and or should i run my tweets on a seperate amp from the mids? and 200 wrms x4 shouldnt be a hard amp to find with a nice built in adjustable xover... i hope Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
01xtreme Posted December 26, 2007 Report Posted December 26, 2007 well it was easy to do the 8 6.5's to the amp at 2 ohm, but now ive got more 6.5's and the 4 tweets im starting to confuse myself ect.mids will consist of 12 6.5's single 4 ohms @ 50wrms each and 4 1inch tweets unknown ohm's @ 50wrms for a total of 16 speakers total, i can get a 4ch amp and run 4 speakers per ch, and have 1 tweeter on each ch, so it will be 3 6.5 and 1 tweet per ch.... and thats 1ohm or 4ohm? if the tweet is also 4ohm.... i think i answerd my own question but can someone double check and makesure im on the rite track, and or should i run my tweets on a seperate amp from the mids? and 200 wrms x4 shouldnt be a hard amp to find with a nice built in adjustable xover... i hope sounds right to me, just 2 questions. 1. do the tweeters have passive crossovers? 2. Do those crossovers have an output that is -12db? I only ask the second because the tweeters might be a little too loud depending on where you plan on mounting them...IMO. Quote My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon...
bigjoe302boss Posted December 26, 2007 Report Posted December 26, 2007 well it was easy to do the 8 6.5's to the amp at 2 ohm, but now ive got more 6.5's and the 4 tweets im starting to confuse myself ect.mids will consist of 12 6.5's single 4 ohms @ 50wrms each and 4 1inch tweets unknown ohm's @ 50wrms for a total of 16 speakers total, i can get a 4ch amp and run 4 speakers per ch, and have 1 tweeter on each ch, so it will be 3 6.5 and 1 tweet per ch.... and thats 1ohm or 4ohm? if the tweet is also 4ohm.... i think i answerd my own question but can someone double check and makesure im on the rite track, and or should i run my tweets on a seperate amp from the mids? and 200 wrms x4 shouldnt be a hard amp to find with a nice built in adjustable xover... i hope I always check at the12volt.com, they have a parallel and series calculator, it would be .8ohms parallel and 20ohms series, so that might be a lil difficult to achieve unless you used a crossover on one 6.5 and tweet to seperate the power and still pull 4 ohms, and that would be 4x4oms=1ohm paralleled. If that helps any. Quote dc lvl 4xl 12 kicker zx1500 2 sets of kicker ds6.5s optima yellow top (extra batt) with big 3 1/0 guage and 3 150amp anls eclipse cd5000 headunit
Ray Posted December 26, 2007 Report Posted December 26, 2007 running active or passive? And the tweets will not affect the overall load. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
mrwigglezdj Posted December 26, 2007 Author Report Posted December 26, 2007 well the tweets xover i know nothing about, its got a purday box lol with one input and on the output its got LF and HF wires and i have no clue what they mean lol..... but no internal adjustments that i could see and no instructions lol Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
mrwigglezdj Posted December 26, 2007 Author Report Posted December 26, 2007 and as far as active and passive ,. thats sound quality stuff and i have no idea about.... Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
Stephen Posted December 26, 2007 Report Posted December 26, 2007 and as far as active and passive ,. thats sound quality stuff and i have no idea about.... passive is running a crossover between the amp and the speakers active is the signal is processed before it goes to the amp. Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
Stephen Posted December 26, 2007 Report Posted December 26, 2007 You can run 4 speakers per channel for a 4 ohm load on each channel and set a hpf at about 60-80hz, the tweeters crossovers will take care of the block everything so its not damaged. Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
mrwigglezdj Posted December 26, 2007 Author Report Posted December 26, 2007 i guess passive, i will use the internal xover on the amp and thats it other than what the speakers have built in... but i will be useing a xover on my subs ... but thats a diff topic lol Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
01xtreme Posted December 26, 2007 Report Posted December 26, 2007 I think they are passive. Quote My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon...
