DC Sound Lab
I'm going to gut my box and turn it in to a 4th order wall for a xl18 m1. Im thinking 3 cuft. sealed and 15cuft ported @ 43 hz off a sundown 3500. The reason I'm doing this is for a wider musical bandwith and still play stupid low. What you guys think ? Any advice would be appreciated .
2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz
19 cubes net 245sq in of port
Sundown 3500 @ .7 Ohm
Sundown 100.4
Rockford Fosgat Power Series
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
1 red top under the hood
2 yellow tops in back
big 3 with 1/0 knukonceptz wire
3 runs of +/- 1/0 knukonceptz wire
IT LBS
15 cubic feet ported maybe a little large...
03' NISSAN XTERRA
(1) AQ3500d
(1) AQ4x90
(1) Audio Control Line Driver
(4) DC LVL 4 15's
Cresendo Mids and Highs
100' of 0/guage
Big Three
Mechman 270a Charging @ 16.5v
(6) XS D1400's
Highest Termlab Score 149.9 at the kick & 166.1 in the Port/ on stock electrical and 1 DC XL M1
Updated JUNE 2012*****MY BUILD LOG
USACI REGION 6 POINTS LEADER 2011
USACI KANSAS RECORD HOLDER 2011
Team DC
http://www.dcsoundlab.com/
I'v been reading the bigger the ratio the better ???
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
No sir ill check it out Thankz
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
My 4th order I buil was 2.5 sealed and about 4.8 ported, I would definitely go with 2:1 ratio. I think it would best. So If u wanna go 3 sealed run 6 ported! Do it you will like it if you build it they will come!
03' NISSAN XTERRA
(1) AQ3500d
(1) AQ4x90
(4) DC LVL 4 15's
100' of 0/guage
Big Three
(6) XS D1400's
Team DC
Ok i got one for ya. Lets say i do a 2:1 ratio 3cuft sealed and 6 ported . With the ported section do i do 6 cuft total or 6cuft + port ???
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
I believe it is after displacements...someone will correct me if I'm wrong.
After displacement!
03' NISSAN XTERRA
(1) AQ3500d
(1) AQ4x90
(4) DC LVL 4 15's
100' of 0/guage
Big Three
(6) XS D1400's
Team DC
