so we do alot of work for a Bronco restoration place down by our shop so they send us quite a bit of these lovely vehicles so we thought we would share one of them with you guys.
we will jump right in to the good stuff noones wants to see wires hanging
dry fit in the car
started to resin it. no matte glass was needed we only needed shape for this console. the skeleton was sturdy enough to handle whatever we put in it and the resin will only make it better
second coat
started on the box while the resin dried
uploading
threw some bondo on the center piece to help with the grooves on the side and make everything look a little better. we rhynolined EVERYTHING we put in. this includes the amplifier, kicks, centerpiece, box, EVERYTHING!
left the box to show some love to the glassed piece
we ran into a small dilemma with the box, we realized that the rear seats protrude when put down. so we made some small adjustments to the box to be able to make it work correctly. so what we did was notched the box a little(we had room to make it work)
so that when the rear seats are down, it fits perfectly
its still getting worked on with a bunch of finishing touches, and wire clean up but a couple shots of the inner kicks.
bars to hold the box down while he is hitting the dunes
DSC_3503.jpg a shot of the amp without the cover and painted
its a XD 700/5
You messed up on the title. It should be 1971 Ford Bronco SQL build
good point. this this is LOUD
