I have a DD-1 and will be tuning my first amp with it here shortly. I keep hearing/reading about guys who are running over the rated RMS on subs and speakers. They all say "keep the gains low" etc. etc. What does that mean if the point of setting gains is to match the output and input voltages? Why would you want to set gains any other way than with a scope or DD-1? Why do guys keep fiddling with gains if there is only one "proper" setting?
I'm just wondering, if you set your gains with the DD-1, which is as high as possible without distortion, is this considered a "high" setting? "low" setting?
I'm going to be tuning a T1000 constant constant power to to SD-2 10's and wondering if I should just shoot for the RMS rating on them which would more than likely have me running them at 4 ohms.
Edited by joblo1978
If you are overpowering your equipment, the subwoofers for example, you can always use different tracks like 0db @ 40hz, (ON THE AMP setting portion where normally i use that only for the deck). That would "tame" them down the bass some and you would still be matched.
Follow my Tweet (Twitter)
I used -5db track on my 9k running 2 Fi BTL 18's and so far no problem.The cone get a little warm if I'm at full tilt for awhile but nothing that's not normal to me.Over powering your subs mean you need to know your system and its limits. Otherwise you will be burning up subs left and right and trying to blame the manufacture for something you caused.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
