FS: 2 18 inch SSA prototypes 4000 RMS; SA 4500 amplifier
Subs sold
This is a old picture of my box and my subs just to show you them installed
First off I would like to say this amp is a BEAST! The Sundown audio amplifier can produce lots of bass for your car.
The reason I am selling this amp is because I sold my car that it was in and no longer have any use for it.
This SAZ amplifier has only 4 months out of box and only 1 month actually used. I have used a lot of amps but this one blows all the competition out of the water!
The defect in this amp is it has a couple of scratches on one of the sides. Look through the pictures and you can see it. Other then that it's a perfect amp!
I am asking for 800 OBO (or best offer)
These are the specs:
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Dual Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 12.8V & Less than 1% THD
Operating Voltage : DC 10V~18V (Absolute Maximum 18.5 volts)
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
Wired Remote Controller
MSRP $2149 USD
Text or call 480-309-1603, my name is Austin! I don't really use these forums anymore so don't try to private message me. However I will be checking bi-weekly on this forum.
I am really trying to sell these items locally (Tempe, Arizona) but if your interested enough we can negotiate.
