EdgarG0721 Posted May 26, 2012 Report Share Posted May 26, 2012 So I'm stalling my friend system cuz he doesn't know I let him drill down the sub to the box and the drill whent trough. So I heard theirs an epoxy to fix it is it true or should I use something else. Their brand new dc xl m1 if it matter Quote Link to comment Share on other sites More sharing options...
kbsmoker Posted May 26, 2012 Report Share Posted May 26, 2012 Goop from home depot Quote www.dcsoundlab.comyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3 SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator Link to comment Share on other sites More sharing options...
EdgarG0721 Posted May 26, 2012 Author Report Share Posted May 26, 2012 Is their only 1 goop or certain type I should look for Quote Link to comment Share on other sites More sharing options...
Tebo Posted May 26, 2012 Report Share Posted May 26, 2012 It comes in a blue tube 7$ Quote 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator Link to comment Share on other sites More sharing options...
windowtinter Posted May 28, 2012 Report Share Posted May 28, 2012 The all purpose not the plumber version. put tape on the outside part you can see. goop the surround from the back side. let dry peel tape if you do it right you really won't be able to tell. Quote Link to comment Share on other sites More sharing options...
