2 AQ HDC3 18's in my 99 Tahoe **LOT'S OF PICS**
that looks kind of like the box i built in my suburban for the 21's. Should work out pretty good for you. Double up on the top for 2 18's i would recommend.
99 GMC Suburban
2 Death Penalty 21"
2 Crescendo BC2000
Boston GT-42 Amp
6 Selenium 6w4p
4 Crescendo tweets
Hi output cs144 alt
Audiocontrol Epic-160
Pioneer DVD head unit
Just have to grab another sheet of birch. But I definitely plan on it!
~Team Nussiance~
Head Unit: Sony MEX-BT38UW
Amplifier: 1 AQ2200d for break in period
Subwoofers: 2 AQ HDC3 18's
Mids and Highs: 1 pair of AQ PA-6.5's and 1 pair of AQ PA Supertweets
Scores: 148.1db @47hz
146db- Dash
143.8db- Headrest
Both on music
Looks good bro. Done yet ?
8 SSA EVIL 15's
4 CRESCENDO 5500'S
2 SINGER HAIRPIN'S
21 XS POWER D1600'S
ALL MCLAREN AUDIO MID'S AND TWEETERS
1 TARAMPS HD4000, 1 TARAMPS HD800
SEX!
I wouldn't use 45s..just a. V on back wall pointing towards port opening..an wooden dowels don't hold bro I took mine out and use allthread.flush mount double baffle should be good..what power are you using
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
looking good bro. i'm interested to see how it turns out, i've been thinking of building the same style box for my tahoe but for 4 15's
Thanks and I'll be posting some vids within the week. Just hoping that it's not too close to the rear doors!
in theory the distance from the back of the box to the doors should be the same is the width of the port, but a couple of inches closer won't make a big difference.
the only thing i recommend is 45's on the back wall of the box to direct the air to the V in back of the port.
pioneer deh-p6200bt head unit.
mb Quart ONX4.125 amp.
Hifonics Brutus BRZ2100.1D amp.
2 sets of Hifonics Zeus ZXi 6.5 Components.
4 ssa dcon 15'' s4 subs.
kinetik hc 2000 battery.
i'm hoping it will sound good once it's installed.
my youtube http://www.youtube.com/user/setman514
read
Going to throw it in the truck today for a trial run
Sounds good. If i use all thread will I have to double the bottom up too? And I'm just going to break them in on 1 AQ2200 then once I upgrade my electrical I'll add another.
huge ass box ftw! :)
Hell Yea!!
Ok good. I was a little worried.
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
My box is single layer birch with a double flush baffle..and all thred top to bottom side to side..I push 17k to it with 4 18s zero flex
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Sorry to hijack this thread. dc98hoe can you send me link or a video of your set up thanks.
