alright guys subs will be in my posession in 2 weeks.
dimensioins are 14 tall 10 for the bottom 5 at the top and it can be from 40 to 45 in long.
looking for tuning around 33 to 38hz
i have the rf bd 1000.....birth sheet says 1396 at 1ohm.
reason i dont want it past 45 inches because i have the xs power 1200 going right beside enclosure. i also have to have room for my other rf power 400.4...............................
can someone design me a box with a cutsheet or tell me how this would work and slot port would be fine or even an aero port.
any help would be appreciated
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
yeah side port or whatever port.......i can go 50in if i have to....... i will just find room for the battery if need be and could go 11in at bottom and 5 and maybe 6 at the top
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
single 4inch aero port firing to the passenger side..build ur box to spec and cut the aero port till its like 4-5 inches from the side wall
this design likes to get low from testing in this truck..i have 2 10" aq sd 2.5's onna db drive 2k doing 45's at the headrest.. same vehicle
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
if you make the box 35 inch long, 14 high, 6 deep at the top and 11 deep at the bottom a single 4 needs to be around 13 inches long but make sure to keep that port around 3-4 inches off of that side wall..this gives you a tuning of around 38 hz which is perfectly fine for this truck..ive had boxes tuned into the 40's in this truck and could still play into the low 30's lol 38 is damn near perfect...anymore questions just lemme know..also your back wall is going to flex like a bitch.. so plenty of sound deadner as well as taking tennis balls and shoving them between your cab and bed will help alot..i know its ghetto but it works lol that or take self taping screws and getting some little 90 degree angle brackets and screw em to the box and then to the back wall...both help
power: dd m4
I appreciate the help.........and I plan on deadening the back wall....also could I go a lil longer and one inch less at top......but if not I will build the box....also it will be built with birch....
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
  • Who's Online   0 Members, 0 Anonymous, 722 Guests (See full list)
