mrwigglezdj Posted November 5, 2006 Report Posted November 5, 2006 and a good "cover up" for the melted jacket that looks proper instead of tape is heat shrink wraper, cut it about 1.5 inches long and move it away from the heat untill youre done and when done slide it up over the new connection and use a lighter to heat the "heat shrink" to cover the discolored/melted wire end...makes for a nice finished look :^ Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
baseballer1100 Posted November 5, 2006 Author Report Posted November 5, 2006 So does the wire need to be smaller then the terminal? Or fit flush around the edges? Quote
ChevyBoy Posted November 5, 2006 Report Posted November 5, 2006 So does the wire need to be smaller then the terminal? Or fit flush around the edges? flush around the edges. thats y u tend to use 1/0 terminals for 1/0 cable. u wouldnt use 1/0 terminals for 4 gauge cable. Quote
baseballer1100 Posted November 5, 2006 Author Report Posted November 5, 2006 yeah well how do you get the solder there? Quote
andym85 Posted November 5, 2006 Report Posted November 5, 2006 ^^^how do u get the solder where? not really sure what u are asking?? i think you are asking how do u solder it if there is no room in the terminal, since the wire fits so tightly inside the terminal...that is why soldering is so good, because the wire fits tightly in the terminal and then when you 'melt' the solder inside the terminal, it bonds the wire to the ring terminal. regardless of how tight the wire fit is inside the terminal there is always room to fill it with molten solder...just try it. get some terminals and wire and practice Quote i likes me some audio stuff...
ChevyBoy Posted November 5, 2006 Report Posted November 5, 2006 i dont think he knows the first thing about soldering. its gotta be tight for plumbing. thats y when u put a copper fitting on to the copper pipe, u can barely pull it back off. if u have room there and "sweat" it on, then u r liable to shoot the fittin off the pipe if u have so much water pressure. tighter is always better :-* Quote
andym85 Posted November 5, 2006 Report Posted November 5, 2006 lol...tighter is better...damn straight but hell, i didnt the the first thing about soldering once upon a time. i went through about 4 mini torches that were complete shit before i found one that works. i fucked up a bunch of soldering jobs practicing, but that is how u learn. like i said, grab some terminal/wire and try and find a good torch for big wire. it takes some time and a little money...but you will figure it out...it aint that hard Quote i likes me some audio stuff...
baseballer1100 Posted November 5, 2006 Author Report Posted November 5, 2006 i dont think he knows the first thing about soldering. its gotta be tight for plumbing. thats y when u put a copper fitting on to the copper pipe, u can barely pull it back off. if u have room there and "sweat" it on, then u r liable to shoot the fittin off the pipe if u have so much water pressure. tighter is always better :-* Thats why i asked i want to know how but i havent a clue. Quote
baseballer1100 Posted November 5, 2006 Author Report Posted November 5, 2006 lol...tighter is better...damn straight but hell, i didnt the the first thing about soldering once upon a time. i went through about 4 mini torches that were complete shit before i found one that works. i fucked up a bunch of soldering jobs practicing, but that is how u learn. like i said, grab some terminal/wire and try and find a good torch for big wire. it takes some time and a little money...but you will figure it out...it aint that hard Thanks man i'm going to go do that now. Quote
andym85 Posted November 5, 2006 Report Posted November 5, 2006 yep.. Quote i likes me some audio stuff...
