xx1 Posted May 29, 2012 Report Posted May 29, 2012 hello. I'm new to big car audio, many of you guys inspired me to start on this journey. I recently purchased 2 fi BL 18" and I'm about to start the build of my first enclosure ever. (I've only owned prefabs) and I'm trying to understand port tuning and volumes, fq. after a lot of reasearch I came up with this simple design. My questions: is it ok? should I make it bigger? smaller? its it properly tuned? (I want a loud daily setup) port??? longer? shorter? wider? narrower? I'm going to add 45's to the inside corners. do you think it will need bracing? or the port will act as one? in general what do you think??? thanks for your input. audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
loudNlow87 Posted May 29, 2012 Report Posted May 29, 2012 Ahh!! The RE calculator.. Download Torres' calculator and plug the same numbers in and play with it. It's much more accurate and allows to compensate for bracing, woofer displacement, etc. '11 Jeep Patriot New Build Head Unit: Pioneer AVH-P3200DVD Front: Massive CK69 Components Front Amp: Massive NX2 Rears: Infinity Kappa's Subs: 8 Sundown SA-8 v2's Sub Amp: AB 450.1 XS D3100 Come on 150!
xx1 Posted May 29, 2012 Author Report Posted May 29, 2012 thanks! I didn't knew that software. it just made everything easier. audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
getlocivic Posted May 29, 2012 Report Posted May 29, 2012 please DO NOT USE THE RE CALCULATOR.. not accurate at all.. general idea for a box... go for 6 to 7 cubes each tuning at 29hz is fine keep the port area in the 14 to 16" per cubic foot double baffle where subs mount and braces for the back wall and the sides subs up port back in suv's and hatchbacks
