Hey I'm a noob, but i have a quick question. i just installed a 1500.1 crunch amp into my friends sentra and it like cuts off and sounds like its skipping its weird. u think the ground that i used isn't strong enough?
3 12" Alpine Type-R's
1 Hifonics 2010d amp
does it shut off when the volume is up high? if so the ground is loose and you need to tighten it
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
it like cuts off like clipping. and yes it is when the volume is high. and ground is tightened. do u think the ground is shitty. kuz i think there was some paint under it i really didnt check
use a grinder and grind, or sand down the ground location, and also check for loose positive connection, at the fuse, batt terminals, and amp as well
the last possibility is kinked RCAs, or rcas with a bad connection, possibly a broken wire at the rca connection
IF the rca is used, or generic
might be the RCA's because its a stock headunit and he had an rca converter and i really have never used that before so i just cut into regular wires coming from the speaker.
