94 eclipse gsx awd built for sale
modifications listed here it is the second most modified car on kentuckydsm.com all it needs it the timing belt tinsioner and timing belt pulley to be up and running again
Engine
Modification
6 bolt block
6 bolt head
acl tri metal race main and rod barrings
all emissions crap removed or blocked
ams race balance shaft elimenator kit
ARP Harmonic Balancer Bolt
arp head studs
arp main studs
bc 1 mm over valves
bc 272 cams
bc valve springs and retaners
bored .020 over
Cometic head gasket
crower rods
custom brc pistons
Fully balanced internals
gapless rings
greddy timming belt
itm revised lifters
Kiggly Racing 6-Bolt Main Girdle
magnas heat barrier intake gasket
silicone vacumm lines
supertech valve guides
Transmission
act 2900 street clutch
all new driveshaft universal joints
driveshaft yoke recall kit
Extended Clutch Slave Cylinder Rod
fidanza flywheel
in car solid shifter bushings
new driveshaft carrier barings
new oem pivot ball
new shifter fork
stainless steel braided clutch lines
Brakes
stainless stell braided lines
Intake
2.5" intercooler pipe
94 throttle body
greddy bof type rs
k&n air filter
Exhaust
2g ported exman
3" megan racing dp
3" megan racing test pipe
3"megan racing cat back
ported o2 pipe
stainless steal wide band 02 bung
Turbo
custom adjustable wastgate
oil feedline w15 micron filter stainless steal braided-4an
oil return socketless hose fitting -10an
ported cliped big 16g turbo
push to lock -6an water line
Intercooler
cx racing fmic
Fuel Delivery
650cc injectors
aem fuel rail
fuel lab afpr
fuel lab fuel filter
pump rewire
push to lock -4an return line
STM FUEL TANK TO RAIL KIT
walbro 255lph
Engine Management
2g maf
2g mas adapter wiring harrness
apexi safc2
data logger on a palm
greddy boost controller profec spec b II
greddy full auto turbo timer
stage 3 keydiver chip
Miscellaneous
cruse control removed
removed all ac
Ignition
94 cas
95 coils
95 power transistor
ngk plugs
ngk plug wires
Fluids
BG Syncro Shift II
Diaqueen Transfer Case/Rear Diff. Fluid
dot4 brake fluid
moble1 full synthetic 10w40
Gauges & Sensors
autometer phantom water temp gauge
autometer phantom boost gauge
autometer phantom egt 0-2000 gauge
autometer phantom oil press gauge
autometer phantom wideband o2 gauge
custom fiberglass vent dual gauge pod
triple a piller gauge pod
im asking 7000 cash or stereo equipment trade equal to 7000 if i have forgot any thing for the rules please let me know this is my first for sale thread
also there is videos on my youtube channel the performance shop
How many miles are on the motor as it is now? On the block overall?
What turbo is on it?
Is it an obd-II car?
Any dyno time?
You dont have smog/emissions checks in Kentucky, do you?
SMD Super Seller
My Feedback Thread
no smog or emission checks in most states it is not road legal it is in my state lol motor has about 20 miles on it body has about 160,000 block original had 80,000 miles on it head has 0 miles on it seance i put new valves in it but im about to start ordering the parts and tools i need to get it back up and running then the price will go up turbo is listed its a big 16g ported and clipped no dyno time
  • Who's Online   0 Members, 0 Anonymous, 1096 Guests (See full list)
