Hey guys. well after sitting around for a few days and getting bored. i thought id upgrade my stereo system. my old system was 2 12 treo TE wired at 2 ohm on at 350 watts. sound good n all but i could still breath in the car and was bugging me. so i went on a shopping spree online and whatnot. bought a kenwood DD 319, 2 hifionics brutus 2400.1 amps, 100 feet of Xp flex 1/0 wire, 100 sq ft of fatmat and a bunch of other crap... going to be taking pictures of the system rebuild, the new box build, new subs and everything.
of course i bought a DD-1 and SMD hat. heres my daughter reppin the hat
The XP wire. 2 50ft rolls of 1/0. one red and one blue.
wire thickness XP flex
soldering the wires for the new wire harness for kenwood DD 319.
Edited by boostin302
My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/
2001 Ford Mustang GT
4.6 SOHC 380HP
270 amp Mechman alt
2 12" Treo SSX custom built.
6.47 cu ft, tuned to 32Hz
2 hifonics Brutus 2400.1, strapped
1 optima yellow top
1 Kinetic HC1800
14.4v @ 29Hz, 2k RPM
over 100ft 1/0 XS flex wire
Big 3 in 1/0
100sq ft fatmat deadener
145.3 on music, 142.6 sealed on music
Stop being a pussy and wall it off.
I hate when my google breaks too
I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
Test fit of the new deck
Such a empty hole with no deck
New deck fully installed, wired up. all wires soldered and heat shrinked
SMD hat staying in the house, staying clean
UPS finally brought my amps
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
the new subs are treo SSX 12's. dual 2 ohm. going to be running a ported box, ported through the rear deck with the subs firing foward ( towards the rear seat). running 2 optimia batterys and a mechman 270a alt that i bought from jasonjones on here. i'll post more pics as i get more work done it. laying the fatmat tomorrow in the trunk and trunk lid.
have any questions, post them and i'll be sure to answer them guys..
thanks all.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
For some reason the trunk likes to rattle like a mofo. I was going to run that fat mat under the seat and under the headliner as well.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
Do you plan on sealing off the trunk completely? Or just forwards firing and ported through the rear deck? Either way I'd say deaden that trunk... Those Stangs rattle like a mofo... And btw... GET TO WORK! Needs moar build log pics!
ive been tossing around the ideal of sealing the trunk off. trying to think of the pros and cons of it but as it stands, the subs will be firing foward and ported through the rear deck. sound deadener pics coming up
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
heres the pics of the sound deadener install. i used fatmat brand. seems to stick really real and easy to form around corners. heat gun helped also. i cleaned all the areas for it with purple power cleaner.
trunk before install
making a cutout out of cardboard for a tight spot.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
the trunk lid getting its fatmat installed
thats all i have for some reason. thought i had more.. next pics will be of box build, wire install, subs, amp placements..
thanks for looking,
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
  • Who's Online   0 Members, 0 Anonymous, 1330 Guests (See full list)
