Liking the alt setup man
Team Big Un,Team DB Drive, Team DB Driven, Team Xs Power
Team Ohio Gen, Usaci 2-4 modified champ 5 years in a row
build is getting big....... quick.
glad to see another big build from you. Would like to see the old truck though, was always my favorite.
Andrew, are you going to have all three alts controlled by the PCM together or are you having two separately dedicated to the NS1's?
1 is controlled by the pcm and the other 2 alts are controlled by a relay provided by DC Power
Team Ampere Audio
  • 3 weeks later...
So I have been doing a bit of small things for the build and started on the A Pillars today. Dropped the headliner which is a huge pain in a Tahoe and got a layer of Audio Technix .80 mil down. All wire connections are being soldered and heat shrink added. Before the deadener was applied all of the area was cleaned with an alcohol mist and wiped down until clean. Battery connections are temporary and will be redone when Toolmaker finishes up the 1/0 terminals
Team Ampere Audio
