1/0 wire not fitting into 1/0 terminal
I've never seen it done but if you could find some copper tubing that just fits on the wire and cut it to the right length and solder it on the wire like you would a terminal then put that in the power wire hole it might work. Plus your amp sliding around is bad, is your power wire fused? I hope so because if that sucker falls out and shorts you don't want a fire.
Haha yea its fused, that's the first thing I did. It's secure for now I just screwed down the amp for now.
If it comes out again I'm going to get some 0 gauge reducers to 4ga which should be fine
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
Did you cut off enough insulation? It might not be fully reaching the set screw
No I removed the screw to see and its in there, I just took a little drive before and it stayed in, I will take more of "my kind" of driving in a lil bit to see if they stay and wit the amp mounted
Get some pictures up for us :)
Also, try tightening it then taking a dry-erase marker and putting a line between the screw and the terminal so you can see if it loosens itself.
The set screw doesn't move, the wire like breaks apart and slides out cause I think its a crapp connection
  • Who's Online   1 Member, 0 Anonymous, 447 Guests (See full list)
