Ok so a week ago I installed some 1/0 kunkconceptz wire & ran it to my 2011 zx1500.1 I had to cut a few strands off to make it fit but if I move the wire at all it keeps coming out...any ideas of how to fix this?????
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
Did you tighten the wire in the amp? it shouldn't come out. Also Knu 1/0 is closer to 2/0.
I tightened it as much as I could,everytime I move it it.keeps breaking off and coming out...
I don't know how to post pictures, & I cut like 50 off mybe....I do have a good amount of slack and my amp slides around when I drive but the connections should be more solid. I just mounted the amp to the floor hopefully that will help
