ok now this is what you should do next, have the brain out and find out which wires control the actuator and check the voltage on it when you click the button for it to pop, if it is getting volts then you know the actuator is going out if its not getting volts then you know there is a problem with something else.
whats wrong with fat chicks? they are like mopeds, as long as your friends dont see you riding it, they are a blast! hahah
I am dumb as a stump. I live in the south and we are all dumb here.
I agree, and was also my plan. Check voltage to the actuator first.
Yep thats the best way to troubleshoot the voltage then c from there. Ay op did you do anything or get it fixed?
I
Im getting ready to check voltage. Everything seems to be working fine just that issue
when you say button then remote..how is button wired through its own relay? does brain have built in relay packs? when fully closed is takes more effort to pull the latch,meaning more amperage through solenoid.. its definetly electrical orientated,, check grounds.. most solenoids the housing is ground.. make sure the mounting points are paint free.. plus lube latch mechanism up so it move easier..that will help pop also
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • Who's Online   1 Member, 0 Anonymous, 1355 Guests (See full list)
