Kenne Bell 2010 Mustang GT: Speed (slow) and Sound Build
Meh, you get a long blade and you could do it. Cause the blade will bend to allow you to go straight along the top and bottom plates. Then of course the vertical cut is easy. I used to do it all the time with mine when I was contracting etc. Otherwise I'm not sure short of taking the whole box apart. In that case you might as well build a new one.
Another thought, although not pretty, is take a jig saw, and run it up so the table is against the top or bottom and cut that to the vertical cut. Cut the vertical cut out, all the way from bottom to top. Then you have the little, should be 1" to 1 1/2" slivers. You'll pry those off, or chisel them off, or whatever you need to use to get em off.
Do it, you know you want to. I can make payments on mayhem ;)
formerly known as Blue86f150
this sux camel dicks
