Bigger box?
I don't know if it matters a whole bunch, but its 1.25 inches, not 1.5. And I now realized I should've rounded the edges some.
Sub Stage:
Sa-8 V.2 in a .72 cu ft box tuned to 33 hz
AQ 1200D
Upgrades:
Big 3
Battery
Bought from: Kevin@skaraudio, RooTxBeeR, UtkNate, dgaf
That blows. Haha. Would you recommend a bigger box? If not, I'll probably just go with the design you gave me earlier.
Sub Stage:
AQ 1200D
Upgrades:
Big 3
Battery
If you can open it up fit 45 in the cnr and seal it up again and try that.
Also with the last bend you want that straight to the side and not to the front, so as the sub doesn't unload straight into the port
Also
Didn't see the port size propley as I'm mobile but 10.5x 1.25 in 0.64net is smack on where you want be, with the exception of a but a bit lower tune would be nicer
Yes idd do a bigger box but not bigger in net cuft
Idd stick with 0.6cuft net 8.5-9sq" of port
32-33flat hz and if you have some good mids 30-32hz
Try not to tune over 33 flat unless you no the peek of you car or you just want load, theis still play load low at 33 and some people will even tell you to go down to 30hz
But I've found 32-33flat is best for all round performance,
Also
I'll have to see what I can do. I dont know if I'll be able to open it up. How would I be able to tune it lower with this right now? More port?
That last port piece matters? Just because of loading issues?
Sub Stage:
AQ 1200D
Upgrades:
Big 3
Battery
Install the sub backwards and the box will tune properly, see if it hits the lows as you expected, if so then redo the box to that spec, i you don't want to work a lot on the port do a simple L port, those work best. I saw a preliminar spec for the v2 and allowed for up to one cube net but that should be up to rated power, I think you are better off on what you have now.
  • Who's Online   0 Members, 0 Anonymous, 1403 Guests (See full list)
