HarrisonGrayLetchworth Posted June 8, 2012 Report Posted June 8, 2012 Ive noticed when my voltage drops the bass knob has more resistance to turn. Anyone else had this happen to them? It's not enough to stop you from turning it but I can tell. 2011 Mazda 3 Sport -QL-MZD723 Touchscreen -AQ2200 -(2) Fi SSD 12's -4.3 cf box sealed to cabin -1/0 knu power wire -XS D3100 and 102 AH C&D -Big 3
jeffrm Posted June 8, 2012 Report Posted June 8, 2012 Ive never seen anything like that. What I would do is ditch the gain knob, set your gains correctly, and get a pac lc-1 knob. Much safer on equiptment if you set gains then use pac knob to cut rca signal. 03 tahoe z71 4 death penalty 18s 2 ampere audio 3800s @ .5 each 18v 156.7 @ 35hz 158.5 @ 50hz
Guest Posted June 8, 2012 Report Posted June 8, 2012 lol what? thats impossible edit: the knob is probably more "worn" on the looser parts, meaning that its been in that range longer than the "tight" parts
zack_e89 Posted June 8, 2012 Report Posted June 8, 2012 I have an AQ2200 and i use the bass knob....never noticed that at all. 97 Suburban 8 custom PSI Platform 3 18's
zack_e89 Posted June 8, 2012 Report Posted June 8, 2012 Ive never seen anything like that. What I would do is ditch the gain knob, set your gains correctly, and get a pac lc-1 knob. Much safer on equiptment if you set gains then use pac knob to cut rca signal. What's wrong the the AQ bass knob? From my understanding, when the knob is at 'max' you're at the gain that your amp is set to(not past that), and when you turn it down it just lowers the gain. 97 Suburban 8 custom PSI Platform 3 18's
