Ok so Im kinda confused I got a sa-15 which Im running to a hifonics brz-1700 which I planned on running 1 ohm. Well to make sure I went on the wire wizard and it said this..http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=4 how I was gonna do was link both Pos neg hooked together then wire coming from pos and neg to pos and neg on amp what do I do?
1ohm= ++ -> amp+
-- -> amp-
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Do you have a dual 4ohm sub or a dual 2ohm sub? A dual 2ohm sub can be wired to 1ohm, a dual 4ohm can't be wired to 1ohm.
Ya our if u can just run it between the pos /neg on sub and one wire from pos/neg to amp. The 2nd and 4th after the rem slot. Running same amp btw
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Ya sorry it runs 1200@2 ohm so that would be perfect j just follow the wizard but there is --++ on the amp which set of pos and neg I use?
The first of each side our the second. I tan the.bb second of both. The ones to the right
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
  • Who's Online   0 Members, 0 Anonymous, 2447 Guests (See full list)
