Need help tuning a sealed enclosure with a JL 10W7 powered by a JL 500/1.Really looking for a good starting point as far as initial amp settings.Not looking for a low,low hitting sound.More of a tight sound.Less "buzz" more mid punch.Looking to build a custom fiberglass enclosure, so it won't be the traditional "square/rectangular" design.How will that design affect sound, an what kind of size/dimensions should I be looking at?The build is a 2000 Integra.Going to have two 10W7 in two separate "mirror" enclosures, so any suggestions would be great.Thanks.
You don't tune sealed enclosures, you just give the recommended airspace.
maybe tune is the wrong word. what are some baseline fact numbers to setup the amp at(i.e. gain,etc.) to achieve a good overall sound.
An O-scope or a DD-1 to check for clipping and tune just under if you want max clean power. Telling you a setting is impossible because it's all about matching voltages with the HU and amp. It also depends on the voltage the amp is being fed by the vehicle. To put it bluntly, NO one can tell you to put your gain at so many quarters of a turn or a numbered setting, because it just does not work that way.
Gain depends on your RCA input voltage, typically it is better to stay away from bass boost. Crossover to what sounds good to your ear but generally in the 50-70hz range. That's about it.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Luckily you got some great sounding subs so building should be easy. Contact jl and ask them what they recommend for ported and sealed.
Build both and stay with what you like. I've built two jlw7 12 in a ported box and they sounded fantastic in all music.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
