over the weekend i installed 2 pair of alpine type s speakers in the factory locations of my chevy venture as well as an alpine cde-9874 and a 1/0 gauge kit from rf . i ran my own speaker wire for the type s speakers and am running them off a tma 360.2 amp , 2channels at 2 ohms .
i noticed after a couple of minutes of listening that i seemed to have some noise , mostly out the tweeters music is less noticeable than test tones , very noticeable with test tones. not so much a like an alternator noise but more like a distortion . i have it with the engine on or off , i tried my old alpine deck and had the same noise , i also tried a ground between headunit and amp and still had the noise .
the only thing i can think of is that i do have power cable and signal cables and speaker wire within a few inches of each other .
any help would be appreciated
did you install the crossovers on them alpines?
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
yes , one pair is component and the other pair is coax , but crossovers yes
while i have been waiting for reply i have since tried running only 1 set of speakers off my amp and still have noise , have also moved signal cables away from other wires , still have noise/distortion . would have swapped amp but i don't have another amp so i am now wondering about my amp at this point .
where is the gain on the amp set?
on the lower side , less than half , my deck has 2 volt pre-outs , have noise at all volumes . the noise is maybe like a fuzziness from the tweeters mostly
have you tried different rcas?
no , the rca's i am useing come with my rockford fosgate 1/0 gauge amp kit , i guess i will try that next . would like to think my rf patch cords are better quality than what i have seen at this point
could be a slight manufacturer defect it happens
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
