Soundigital 16k x2
the 2 16k are both in working condition... 1 is like new, only used at finals for 2 burps(1750+85shipping). The other, well it's been thru 2 finals. Including a 158 db crx and a 156 db truck, back cover comes off so it's mounted on a board. 1350+85 shipping.
Seriously these amps take time to come from brazil. If u want one today these are avail.
If not I can keep them, as they just keep winning.
cheaper ones on the bottom here...
Yuli wired his down pretty low and had said he had no issues.
I would not try it. No reason. it will make tremendous power at 1 ohm.
The newer one at the top has never been below 1 ohm.
I still have both: Reason for selling is i moved to a 2000 watt class and well, lol they ain't legal there. Currently using a B2 Mono.
one of these amps came from our car.  we ran them at 0.5 ohm starting and were getting almost 13k watts out of the pair on only two 12v batteries with car off. very good amps if u are looking for power, you dont need to run these at anything lower than 0.5 ohm, they make very good power anywhere from 0.5 to 1 ohm.
we also tested this amp on a 7 battery bank of of 12v batts, with car on sitting at 13.7v one amp wired to 0.7 ohm produced 9600 watts
  • 2 months later...
