alenv10 Posted June 14, 2012 Report Posted June 14, 2012 2 12 INCH KICKER CVRS 34-38HTZ MAX DIMENSIONS ARE 38x17X14 WANT A BOX WITH 0 COMMON WALLS, LIKE A 6X6 IN THE MIDDLE OR SOMETHING.. IF POSSIBLE THANKS NOTHING DOWN HERE YET OBSIDIAN FTW
alenv10 Posted June 14, 2012 Author Report Posted June 14, 2012 anyone's help is appreciated NOTHING DOWN HERE YET OBSIDIAN FTW
alenv10 Posted June 14, 2012 Author Report Posted June 14, 2012 im guessing no? NOTHING DOWN HERE YET OBSIDIAN FTW
dcm4588 Posted June 14, 2012 Report Posted June 14, 2012 what is it you need help with? 07 Ram quad cab - Pulled the rear seatsDC audio XL 18 m1, PSI reconed dual 1 ohm, triple leads, 4 layer stiff spider wired up to a 2 ohm load 4th order bandpass 2.5:1 ratio tuned @ 45hz AP3000.1DBig 3 done in 1/0Odyssey PC1700 up frontOdyssey PC1500 rearAlt in the near future..." In the end, the "what if's" of what could have happened are what hurt the most..."
donpablo Posted June 14, 2012 Report Posted June 14, 2012 Instead of a square port you can do a aero 2015 F-150 Platnuim
stroupe79 Posted June 14, 2012 Report Posted June 14, 2012 i take it your measurements are 17height 38width and 14depth? good luck getting about 5cubes with a port thats 6x6 in the center without having it tuned stupid high i threw your measurements into Torres calculator and with 17x38x14 and a port of 5x5x12 your tuned at 35hz...but only have like 3.4cubes and just over 7inches of port per foot...thats not gonna work very well those subs like 2-2.5cubes each http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup)
stroupe79 Posted June 14, 2012 Report Posted June 14, 2012 Instead of a square port you can do a aero thats still not very much Port per Foot but its about as good as your gonna get and still not enough cubes IMO http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup)
