Excursion Posted June 15, 2012 Report Posted June 15, 2012 I got a Kicker ZX2500.1 today and hooked it up to my mojos and I was tuning it and as I turned the gain up after reaching certain points the amp will shut it self off im not even nowhere near the half way point on the gain, the subsonic is set at zero, and the filter set at around 50. I do see my voltage dropping very low is this a protection mode the amp uses? Im running a stock battery and stock alternator. I plan on upgrading my alternator and I have a second battery I will be putting in the back and replacing my under hood battery also. I have it tuned low now so my voltage wont drop a lot and wont damage my amp and it is very loud for only having it set at that. I was just wondering if the amp was made to do that or is something wrong with it? Any help would be great.
Bump4life Posted June 15, 2012 Report Posted June 15, 2012 so many things you must do. to put it simple it sounds like your amp is shutting off because you are trying to run 2500 rms off of a completely stock electrical. upgrade your electrical please edit: this will probably be one of the nicest answers you get. so much fail Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
IndianaBassHead Posted June 15, 2012 Report Posted June 15, 2012 what do you have the amp grounded to? That could be your problem. Audio Build Ride: 2002 Chevy Blazer 4 door Head Unit: Pioneer deh-80prs Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2) Mids/Highs Amp: Skar 85.4 Mids/Highs: Skar components Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31 Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/ Perfomance Build 2003 Nissan 350z Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU Exedy Racing Clutch, Built Motor by Racing Innovations Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels 466rwhp Bike 2008 Midnight Blue Kawasaki ZX-14 Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
TylerParrish Posted June 15, 2012 Report Posted June 15, 2012 so many things you must do. to put it simple it sounds like your amp is shutting off because you are trying to run 2500 rms off of a completely stock electrical. upgrade your electrical please edit: this will probably be one of the nicest answers you get. so much fail agreed. Time for Big 3, then batteries/alternator, your choice (alternator may be cheaper than 2 new batteries.) Then batteries to go with the alternator if thats what you choose. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Excursion Posted June 15, 2012 Author Report Posted June 15, 2012 Yeah ive got it set way way down now but your right i do need to upgrade big 3, alternator, and batteries. Ive only got it turned up right under 1/4 gain, and no subsonic. Can i cut a hole in my floor to ground it to my chassis?? What is the best way to do that? I have it grounded to the bolt my seats are screwed to now.
